| | | Forums66 Topics128,157 Posts1,056,875 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Hi all,
I'm looking to get my truck inspected soon and on the road. My 3600 is just a cab and chassis, which P.O. removed the old grain box bed that it had. To pass, I need to get the rear wheels covered. I did pick up a cheap set of rear fenders that aren't great, but will serve the purpose. I was wondering if anyone can show any examples of using some kind of lumber just over the axle which would be sufficient to hold a pair of fenders on? Also, I have the rear fender to frame brackets, but nothing else to align the fenders over the wheels to. Any suggestions?
Thanks as always! | | | | | Joined: Feb 2004 Posts: 29,852 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,852 | I used two pieces of 1" square tubing C-clamped to the frame rails and sections cut out of a 55 gallon oil drum for temporary fenders on the pickup I built up for my son. Jerry
| | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Thanks Hotrod - I had considered something like this, until I found the fenders. I'm thinking a few pieces of lumber running fender to fender, bolted to frame, with a plywood backing to bolt the frame to. This won't be long term. Can anyone help with fender placement? Thanks! | | |
