1 members (Hotrod Lincoln),
49
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Having the cab of the COE blasted down to bare metal all over. Normally I would have covered it in the same old primer I've been shooting for 50 years, but thought it would be a great time to use PPG 2K primer. There is still body work to do and even some cutting and welding. Normally no problem with the old primer. Am I going to have any problems spot painting these areas with the 2k? Plan to sand and shoot a final coat of primer before color coat of PPG Concept. | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | I primed mine with epoxy primer. You have it all down to bare metal, why not spray it with something that will likely outlive you? It lays down nice and sands a lot better than I expected. Once you get done with the body work, give it another coat to seal in any filler. This can be done one area at a time if you you cannot knock out the cab body work in quick order. Carl
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Rattle can primer could out live me at this point. | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | I don't know if you meant that to be funny Jim, but I'm sorry that I couldn't help from chuckling at that one. Carl
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Old guy humor.
However, I've used hardware store primer on smaller projects for decades and I've never had a case of the primer failing once it was painted, so I don't know how some can last "longer" than others. | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Just follow the money. Higher profit margin on epoxy primer.
