| | | Forums66 Topics128,049 Posts1,055,548 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 102 | Hi All, My question concerns the center metal strip that runs down the middle of the vent against the screen and turns back to the back of the vent. Mine is bent in a "S" curve so elegantly that I wonder if that is the way it is suposed to be. My gut tells me that it is bent and needs to be straightned. How should it be?
All the best, Ted
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | The vertical strip on mine is fairly straight. If yours is still functional though and you like its present config then keep it that way. If you need another one though drop me a line. | | | | | Joined: May 2006 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 102 | Thanks Huston 54. I straightend mine out and it looks great.
All the best, Ted
