5 members (DannyW, treegrower, baldeagle, Gdads51, 3B), 75 guests, and 6 robots.
Topics128,014
Posts1,055,328
Members48,419
#1214996 04/27/2017 6:37 PM
Having the cab of the COE blasted down to bare metal all over.
Normally I would have covered it in the same old primer I've been shooting for 50 years, but thought it would be a great time to use PPG 2K primer.
There is still body work to do and even some cutting and welding. Normally no problem with the old primer.
Am I going to have any problems spot painting these areas with the 2k? Plan to sand and shoot a final coat of primer before color coat of PPG Concept.
I primed mine with epoxy primer. You have it all down to bare metal, why not spray it with something that will likely outlive you?
It lays down nice and sands a lot better than I expected.
Once you get done with the body work, give it another coat to seal in any filler. This can be done one area at a time if you you cannot knock out the cab body work in quick order.
Carl
Rattle can primer could out live me at this point.
I don't know if you meant that to be funny Jim, but I'm sorry that I couldn't help from chuckling at that one.
Carl
Old guy humor.
However, I've used hardware store primer on smaller projects for decades and I've never had a case of the primer failing once it was painted, so I don't know how some can last "longer" than others.
Just follow the money. Higher profit margin on epoxy primer.
