4 members (PAUL Berardi, Gray_Ghost, JW51, moparguy), 123 guests, and 2 robots.
Topics128,111
Posts1,056,244
Members48,437
Would someone with access to casting numbers be able to provide any info on this manifold ?
Casting number appears to be 3830168
Was in a junk box with a 235 head.
Cheers,
Grizz
If it's stupid but it works ... it isn't stupid.
Split exhaust manifold for 235. Good find
One was used on the early Blue Flame Six 235ci Corvette. Maybe someone will check the casting code?
You just found about a $1500 exhaust manifold! Jackpot!
As Tim said, they were used on the '53-'54 Corvettes, but many more were sold as accessories by the dealers because they were a bolt-on for any 235 or 261. Dealer retail price back in the day? $15!!! I have read that the majority of the production was sold as dealer accessories. If we had to rely on ones that came with Corvettes, they would be even more rare. Notice how the manifold allows for the use of the heat exchanger with a stock intake manifold.
You would have hit the Power Ball if it was attached to three carb Corvette intake.
Matt
Did you mistype the number? 1953-55 Corvette Exhaust Manifolds are casting number 3836108. Post a picture of the number...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I might have misinterpreted the numbers, but I most certainly did *not* "mistype" anything wink
Casting Number
As you can see, the numbers are sufficiently degraded to where the zeros and the sixes are indistinguishable. It could very well be "3836108." To wit, I will accept "3836108" as the correct interpretation of the casting number depicted in the image.
Thanks for the proper reference.
Cheers,
Grizz
Yep, it's pretty well degraded. Let me bail you out of this dilemma. I will even venture into the "backwoods" where ever that may be. How does a cool $100.00 cash sound?
PM me with directions. I can head out in an hour from now.
That manifold can be duplicated with a hacksaw, a hole saw, and a welder- - - - -There's even a seller on Ebay that has a kit for sale to add a second outlet and put a partition between the front and rear sections. The only advantage to having that one or one like it is the casting number. Even a home-brewed split manifold beats the Fenton dual setup without a heat riser.
J Online: Content
Carl, you don't want another piece of junk lying around. Allow me to relieve Grizzly of his burden.
1951 3100
The 12X24 shed is only half full, JW.
