| | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 12 New Guy | | New Guy Joined: Jan 2001 Posts: 12 | Would someone with access to casting numbers be able to provide any info on this manifold ? Casting number appears to be 3830168 Was in a junk box with a 235 head. Thanks
Cheers, Grizz
If it's stupid but it works ... it isn't stupid. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Split exhaust manifold for 235. Good find | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | One was used on the early Blue Flame Six 235ci Corvette. Maybe someone will check the casting code? | | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | You just found about a $1500 exhaust manifold! Jackpot!
As Tim said, they were used on the '53-'54 Corvettes, but many more were sold as accessories by the dealers because they were a bolt-on for any 235 or 261. Dealer retail price back in the day? $15!!! I have read that the majority of the production was sold as dealer accessories. If we had to rely on ones that came with Corvettes, they would be even more rare. Notice how the manifold allows for the use of the heat exchanger with a stock intake manifold.
You would have hit the Power Ball if it was attached to three carb Corvette intake.
Matt | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Did you mistype the number? 1953-55 Corvette Exhaust Manifolds are casting number 3836108. Post a picture of the number... Mike B  | | | | | Joined: Jan 2001 Posts: 12 New Guy | | New Guy Joined: Jan 2001 Posts: 12 | I might have misinterpreted the numbers, but I most certainly did *not* "mistype" anything Casting Number As you can see, the numbers are sufficiently degraded to where the zeros and the sixes are indistinguishable. It could very well be "3836108." To wit, I will accept "3836108" as the correct interpretation of the casting number depicted in the image. Thanks for the proper reference.
Cheers, Grizz
If it's stupid but it works ... it isn't stupid. | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | Yep, it's pretty well degraded. Let me bail you out of this dilemma. I will even venture into the "backwoods" where ever that may be. How does a cool $100.00 cash sound? PM me with directions. I can head out in an hour from now.
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | That manifold can be duplicated with a hacksaw, a hole saw, and a welder- - - - -There's even a seller on Ebay that has a kit for sale to add a second outlet and put a partition between the front and rear sections. The only advantage to having that one or one like it is the casting number. Even a home-brewed split manifold beats the Fenton dual setup without a heat riser. Jerry
| | | | | Joined: Jan 2014 Posts: 3,689 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,689 | Yep, it's pretty well degraded. Let me bail you out of this dilemma. I will even venture into the "backwoods" where ever that may be. How does a cool $100.00 cash sound? PM me with directions. I can head out in an hour from now. Carl, you don't want another piece of junk lying around. Allow me to relieve Grizzly of his burden.
1951 3100
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | The 12X24 shed is only half full, JW.
