7 members (55shaker, Jeff Ogden, RoadsScholar, Gray_Ghost, Ponchogl, fonz8261, 1 invisible),
82
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,131 Posts1,056,722 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 64 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 64 | Any suggestions on where to locate the roller guides that mount to the bottom of the glass frames. I have searched everywhere and only found 55-59 model year. Just when I thought I was ready to put my doors back together.
1951/54 Basketcase | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | They are not reproduced, Denny Graham had some detail on his photo page on how he made some. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | They make them for a 46. I modified mine and had brass rollers made to fit in the channel. | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | Are you looking for the c-channel which bolts to the glass frame, or the rollers which attach to the regulator? Classicparts.com carries plastic rollers to replace the original leather "rollers" (they don't actually roll). The plastic roller rivets are the same size as the hole in the regulator where the original rivets/leather rollers go, making it an easy install. They work great. Carl
| | | | | Joined: Jul 2015 Posts: 64 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 64 | Thanks guys for the replies The C channels are what I need and think I found an option for Making/Modifying some. I will post back with results. It is strange there are no repro's for the 47- 50 trucks. Ken
1951/54 Basketcase | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | If you have an old one as pattern, it wouldn't be to difficult to fab one up.
| | | | | Joined: Jul 2015 Posts: 64 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 64 | Thanks Carl I would happy with a good pic. I have neither. Fabbed a 1" sample today with two 16ga. 1/2" square tubes. This looks like it will work perfect.
1951/54 Basketcase | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Jul 2015 Posts: 64 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 64 | Thanks Brad That first one is a 51 - 54 side window channel for wind wing door. I found a good one from AZ. to get the length correct. I am going to knock this out tomorrow. The end is back in sight once again.
