| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 7 Junior Member | | Junior Member Joined: Jul 2006 Posts: 7 | I just recieved a shipment from a "popular" Truck Parts and Accessories Company and I am fairly disappointed. I ordered Front and Rear Floorpans, Front and Rear Cab Supports and Inner and Outer Rocker Panels, for both sides. I am not sure if I am allowed to mention the name of this company, but the floor pans and the cab supports aren't even close to being replacements for the stock ones. The rocker panels seem to fit very well and I am pleased with them. My question is.....does any one have any experience with these replacement panels ?? Is there a company out there stocks better patch panels than others ?? | | | | | Joined: Dec 2005 Posts: 4 Junior Member | | Junior Member Joined: Dec 2005 Posts: 4 | I have used those on my 66 and you are right about not fitting. I ended up cutting and bending to fit. Not to mention how thin they are, you better sound insulate the new panels or your cab will be ...not so quiet to say the least. ---Mike | | | | | Joined: Jul 2006 Posts: 7 Junior Member | | Junior Member Joined: Jul 2006 Posts: 7 | Thanks for your input....I got them in but I'm not very impressed with how I had to get them to fit. Like you said alot of cutting and bending. That's too bad there isn't a better panel out there. | | |
