| | | Forums66 Topics128,068 Posts1,055,881 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | '50 3100 pickup. I will be painting entire exterior. Backsides of panels will not be painted with exterior color. I plan on doing a BC/CC job. Will be spraying epoxy primer, high build 2k primer, bc, cc. (Plan on using middle of road paint and products, but will tend to move up on quality rather than down.) What is a safe quanity of the various products to be sure that I have enough, but not a lot left over. Thanks in advance. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Figure on about 5 quarts of each, possibly a little extra on the primer for a perfecty smooth base (you'll sand alot of it off). It took about that much to do my long bed '55.
Bill Burmeister | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | I say 6 quarts of color to be safe. A little extra never hurts, and it is important to have it all mixed at the same time. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | From first hand experience - 2 gallons of base, one gallon clear. There are so many smaller pieces that need special attention in addition to the larger panels. This will leave you with a little left over which is better than needing a little more to finish. | | |
