8 members (Peggy M, DaveV, 2-Ton, TUTS 59, JW51, walter74, moparguy, 1 invisible), 159 guests, and 1 robot.
Topics128,081
Posts1,055,955
Members48,430
#121452 08/03/2006 9:09 PM
What would be the easiest way to fix this problem? I haven't seen any patch panels that would replace this entire vent. Does anyone know of one? Here is the link to a picture that shows the area cowl vent picture
any help would be great
#121453 08/03/2006 10:34 PM
You can get that cowl panel from Jim Carter and other vendors. I replaced that same panel on my 53.
#121454 08/03/2006 11:40 PM
Thanks, I looked closer and did find the patch panel that goes all the way up and includes the vent louvers. It seems to be between 90-100 bucks at a couple different places. If anyone else has smoothed this panel and has the louvers hanging around I would be interested.
#121455 08/03/2006 11:46 PM
Blake51,
I just recently replaced that very panel on my 55/1st. I think the panel was about $80.00. It was a perfect match, and a relatively easy R&R.
I thought trying to straighten or bondo those little louvers would not do justice to the cab..they need to be perfect to look proper.
Those vents are not just decorative, they are a integral part of the fresh air heater.
Stuart
