| | | Forums66 Topics128,124 Posts1,056,334 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2015 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2015 Posts: 59 | I have a oil leak at rear axle 3/4 ton H052 1962 GMC it appears to be leaking between hub and drum,no oil leaking at axle flange, no oil appears to be leaking out of brake drum . I removed the wheel the oil looks like it is leaking on the outboard side of the drum. I bought new axle seals and I was wondering if the hub and drum need to be split apart and sealed up.
1962 GMC 920 step side 261 4 spd
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The oil is sealed by the seal in the hub solely. There is a slinger that has a gasket and is supposed to direct oil that leaked out to the outside. Personally I think that is a pipe dream. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You need to pull the hub & drum & replace the seal. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
