6 members (Otto Skorzeny, Steelonsteel, Guitplayer, Shade Baby, cmayna, Gray_Ghost), 107 guests, and 0 robots.
Topics128,134
Posts1,056,401
Members48,441
#1214269 04/23/2017 12:54 AM
I'm wanting to try to start the truck by bypassing the key in the cab. We have some major wiring issues that need to be addressed (re-wire in order) and I really don't want to energize the whole system. I purchased a remoter starter switch (two alligator clips, hand held switch) that I was hoping to act as the key being turned on in the cab. My son will still use the stomp start in the cab, but when I flip the remote start switch on, it will energize the coil. It this done by simply connecting one clip to the positive battery terminal and the other clip to the + side of the ignition coil? Do I need to run a jumper wire from the starter to the coil also?
Thanks in advance.
Ron and Ryan Hill
1952 Chevy 3100
Yes, run it from battery to coil. No wire from starter.
Thank you sir!
Ron and Ryan Hill
1952 Chevy 3100
