| | | Forums66 Topics128,126 Posts1,056,355 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | I know that the drive shaft needs to be shortened 3 inches. I don't want to cut my original drive shaft. My truck is a 59 1/2 ton all original drive train. I procured another drive shaft and now find that the universal joints are not the same size. The caps are different sizes as well as the width across the joint. I seem to remember 40 yrs. ago you could buy a conversion u joint that would have different size caps, but I don't remember if the width across the caps were different. Any ideas from those who have done this already? How did you do this.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Any driveshaft shop can hand you the crossover u-joints that you need- they do it every day... No prob!
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Thanks Dave, The drive line shop that is shortening the shaft said gotcha covered, don't worry about it. Seems it is a common u joint that gets used.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Sep 2016 Posts: 6 New Guy | | New Guy Joined: Sep 2016 Posts: 6 | You could just as well have them put a more common yoke on the shaft for you that matches the Diff. Either way works.
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | The drive line shop had the conversion u joint on hand. One axis is the width and diameter of a 80's model gm product and the other axis is the size of the older gm products. They said it is a common u joint that is available anywhere if I ever needed a replacement.
