0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 37 New Guy | | New Guy Joined: Feb 2006 Posts: 37 | I have spent a week under the truck, (which for a guy 6-3 and 300 lbs is never an easy task) with a drill and brush getting the loose rust off (hint- don't do that when its 100 degrees out!) I just used my first quart of zero rust, looks great, (Also makes my grey hair a great black color as well and I suspect lasts a whole lot longer than a dye job!)
My question is real basic, with my second quart do I zero rust the leaves? It seems to me with their constant movement its going to crack anyway, what is the correct thing to do? Is there anything else that should not get painted? | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Leaves? Are you talking about the hinges? If so, you can ZR them also. It will not crack off. I have painted mine with the top coat and they seem to hold up fine. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | ZR will hold on where the leafs don't scuff each other, but the factory didn't paint the springs
Bill | | | | | Joined: Feb 2006 Posts: 37 New Guy | | New Guy Joined: Feb 2006 Posts: 37 | thanks, I meant the leaf springs, will leave them alone I did do the hinges | | |
