5 members (Brian Moore, Jims46, Sedgewick, walter74, J Lucas), 63 guests, and 2 robots.
Topics128,030
Posts1,055,423
Members48,422
#1213971 04/20/2017 3:10 PM
I
I Offline
I just have a curiousity. I've looked at valve covers for a 216 and seen that a lot a lot of repos don't have the three slots in the top like the originals.. why?
Stovebolter -- the Next Generation
(I'm 20)
1941 Chevy 1/2-ton pickup
"Lucy"
More pix on Photobucket
1967 Ford Mustang - "Sally"
There were factory changes made to these covers over the years,not all had the slots, trucks vs passengers etc. Pre68Dave has info on all the various covers on his site, someone will be along with a link. Also look in tech tips etc.
1946 1/2-Ton Chevy
Scroll down to page 4 for Pre '68 Dave's 235 valve covers photo from a presentation he gave years ago.
I have never seen an original 216 valve cover without vents.
If you decide to run without vents, you need to plan on a well designed PCV system.
The vents have a dual purpose.
They are there to provide a way for air to enter the crankcase as the fumes are sucked out by the road draft tube while the truck is underway.
They also allow water vapor to escape while the truck is not underway (when the road draft tube doing nothing about the fumes).
Without the vents, water will collect in the valve cover, leaving a milky slime.
Carl
I think that some 216s came with a PCV system - those valve covers would not have had slits/vents in them?
