| | | Forums66 Topics128,022 Posts1,055,376 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2015 Posts: 201 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 201 | I just have a curiousity. I've looked at valve covers for a 216 and seen that a lot a lot of repos don't have the three slots in the top like the originals.. why? | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | There were factory changes made to these covers over the years,not all had the slots, trucks vs passengers etc. Pre68Dave has info on all the various covers on his site, someone will be along with a link. Also look in tech tips etc. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Scroll down to page 4 for Pre '68 Dave's 235 valve covers photo from a presentation he gave years ago. | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | I have never seen an original 216 valve cover without vents. If you decide to run without vents, you need to plan on a well designed PCV system. The vents have a dual purpose. They are there to provide a way for air to enter the crankcase as the fumes are sucked out by the road draft tube while the truck is underway. They also allow water vapor to escape while the truck is not underway (when the road draft tube doing nothing about the fumes). Without the vents, water will collect in the valve cover, leaving a milky slime. Carl
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think that some 216s came with a PCV system - those valve covers would not have had slits/vents in them? | | |
