8 members (cmayna, Wally / Montana, Shade Baby, Goach2, Donf, dt235sd, Otto Skorzeny, Joe H), 60 guests, and 0 robots.
Topics128,119
Posts1,056,311
Members48,439
#1213884 04/20/2017 1:35 AM
I
I Offline
Ok so last week I left a show and go to get some food at sonic (drive in place for those who don't know) anyway while I'm sitting I notice trail of water coming from my truck and long story short it's the water pump, I thought it was my seal job but the water is coming from holes that seam to be factory drilled. There are located right behind the pulley in the pump body, this pump is only like two years old so I'm gonna contact the company but can anyone tell me what those holes are for and why they are leaking? And also why didn't they leak till now?
Stovebolter -- the Next Generation
(I'm 20)
1941 Chevy 1/2-ton pickup
"Lucy"
More pix on Photobucket
1967 Ford Mustang - "Sally"
Factory's way of letting you know it's time to change/rebuild the pump.🛠
I
I Offline
Even though it's only two years old?
(I'm 20)
"Lucy"
I'll bet they tell you "It's only got a 90 day warranty- - - -tough luck!"
They don't make parts like they used to. Sadly Jerry's probably right.😡
I
I Offline
That's ridiculous, ok I have my old pump which was still alright when I took it off, should I put it back on or get a new one?
(I'm 20)
"Lucy"
The bearings are separated from the coolant by a seal. Once that seal leaks, coolant will get to the bearings and pour out the holes. Usually the seal doesn't fail until the bearings are heavily worn.
If the seal was nicked during assembly by a guy (who gets paid a cup of rice a day) because he was working too fast to avoid the caning, a premature seal failure would result.
Maybe the next "new" one will be fine.
At least a water pump is easy to get to and easy to replace.
Carl
V
V Offline
If your old pump didn't leak or squeal go ahead and try it. They are easy to swap.
I don't know how old the water pump is on my 49 216 but it's a safe bet it's been on since 1969 when it was parked for it's long sleep. I'd use a good old part before I would a new aftermarket.
Good luck
Dave
Keep in mind that an overly tight fan belt can cause premature bearing failure and as mentioned above they don't make them like they used to.
Ed
