8 members (GMCJammer51, 68ironhead, carbking, Rusty Heaps, Jeff Ogden, Gdads51, Ridgeback, Phak1), 380 guests, and 4 robots.
Topics128,162
Posts1,057,042
Members48,463
Page 2 of 2 1 2
One of the early Toyota Land Cruiser rear ends just might be what you're looking for. The compact Japanese pickups will have drum brakes and the right lug pattern, but they're probably going to be a little too narrow.
Crusing in the Passing Lane
I thought early Landcruisers had 4.10, would that work?
Ed
I have 30 inch tall tires, and no overdrive.
At 70 MPH, the RPM would be 3,214 with 4.10 gears.
I am looking for low to mid 3s gears.
Carl
Couldn't find what I wanted at the junk yard, so I rebuilt the 3.08.
I found that axle retaining C-clip I dropped 2 years ago, when I put axle bearings and seals in it.
Well most of it anyway. It must have fallen deep into the case behind the pinion gear. It knocked some very small chips off 4 of the pinion teeth, but not where the ring gear contacts them.
Did a thorough cleaning of everything and replaced the pinion bearings/races. Having a bear of a time finding anywhere local which carries a crush sleeve which sets the pinion preload.
Now I am about to experience the joy of setting the pinion depth and backlash. Oh boy!
Finished putting the 12 bolt back together.
I never did find a new pinion gear crush sleeve locally, so I had a buddy make a 3/32" shim the same diameter as the crush sleeve, allowing me to get some additional squeeze out of the old one.
Worked like a champ.
I test drove it today and the rear end does not make a peep. No whine, no howl, no clunks. It is a good day.
Carl
Page 2 of 2 1 2
