| | | Forums66 Topics128,069 Posts1,055,890 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 19 New Guy | | New Guy Joined: Sep 2013 Posts: 19 | I would like to put a different tranny in my 41 burb (216 engine) that has synchronizers in it. (mine is shot also). What can I bolt up to the 216? I realize I will be swapping out the rear for an open driveshaft.
'52 GMC, '41 Suburban and '28 Chevy Street Rod
| | | | | Joined: Sep 2013 Posts: 19 New Guy | | New Guy Joined: Sep 2013 Posts: 19 | Oh Yea, It has a 4 speed.
| | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | You could use a 41 3-speed transmission, it was sychronized. Same gear ratio in high gear, 1-1 as the 4 speed. My 39 stake truck has a 3-speed. Bonus with a 3 speed you won't have to double clutch to shift. You could keep your existing rear end, torque tube assembly. Just a thought.
Rick
1939 Chevrolet Stake Truck
| | | | | Joined: Sep 2013 Posts: 19 New Guy | | New Guy Joined: Sep 2013 Posts: 19 | Will that come up thru the floor or did they have it on the tree then?
