Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Sjm, Stovebolt48, Otto Skorzeny), 177 guests, and 4 robots.
Topics128,278
Posts1,058,457
Members48,490
Hi, don't know if any of you have a solution but my rectangular door mirror really shake a lot, enough that they are kind of useless, especially at higher speeds. Has anyone come up with an improvement? Would a smaller mirror work better? I've checked and they are mounted tight to the door and the mirrors tight to the arms. Thanks Kevin
Thanks, keep truckin!
The original mirror for your truck was a round mirror, the rectangular were on larger trucks. I'd try the round ones and see if that makes a difference. If not, you might have something loose under the cab sending a vibration up and the mirrors are vibrating in sympathy.
1959 3100 Apache Fleetside
Might just be tired, hard cab mount rubber.
You might have a vibration somewhere you're not aware of. My mirror use to vibrate but the truck felt fine. I replaced my U-joints one day and for the heck of it had the drive shaft balanced. My mirror stopped vibrating after that.
Also, one day I started up my freshly rebuilt 270, the mechanic and I checked everything over and I was about to back out of his shop and take it on its maiden voyage. As I looked in the rear view mirror I noticed a barely perceptible intermittent blur. It couldn't be heard or felt, but you could see it in the mirror. Long story short; the engine was bad and I have a new mechanic.
The point is; the slightest vibration in the engine, drive shaft, wheels/tires, etc. is exaggerated in a mirror because you're not looking at the mirror you're looking at a point sometimes half a mile away.
Thanks guys, I think I will go to the smaller mirrors as an option, I have not done any improvements underneath so that seems to have an effect. Thanks
Wheel balance and/or bad shock absorbers will also set up a harmonic vibration in a set of mirrors.
I use the round peep style on my 54/3100.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
