4 members (cmayna, Hanks custodian, walter74, 1 invisible), 54 guests, and 4 robots.
Topics128,056
Posts1,055,800
#1213391 04/16/2017 7:39 PM
Is there any way to tell the original color of a 1952 3100? I noticed that passenger cars have a model id tag on the cowl.. Do trucks have something similar?
Thanks, cuzin
cuzin #1213399 04/16/2017 8:14 PM
Unless the bed was removed for any repaint job, the back of the cab and front panel of the bed should still show the original color. May be faded quite a bit, but you should be able to match it with the fairly limited selection of factory colors. I don't know the actual numbers versus other colors, but most pickups were painted forest green.
cuzin #1213409 04/16/2017 10:22 PM
1952 USA Chevrolet truck color information.
As posted by Kevin:
Forester Green was the regular/standard color.
There was no color code tag/plate/indicator in that year.
tclederman #1213413 04/16/2017 10:51 PM
If you have a patch of paint somewhere, preferable a vertical surface, that is not rusted through, wash the dirt off, give it a good going over with rubbing compound. A final rubbing with polishing compound and a coat of wax and you will have no problem identifying it from the color swatches for that year. It's not like there were 10 shades of blue.
cuzin #1213416 04/16/2017 11:37 PM
You might take a look under the hood. I've seen many GM trucks and cars with the color name and code written on the underside of the hood.
Bill Burmeister
cuzin #1213420 04/17/2017 12:32 AM
Thanks everyone. Basically, without evidence of original paint showing somewhere, there is no official plate with a paint code. So, you can re-paint the truck any of the colors available (including two-tone) and it would be considered original. Let me know if I'm wrong.
Was the two-tone any color with black fenders only?
Thanks and Happy Easter, cuzin
cuzin #1213423 04/17/2017 12:42 AM
No, a repaint won't be considered original. Original paint is the paint applied at the factory. It would be considered factory correct.
cuzin #1213436 04/17/2017 1:29 AM
In 1952, two-tone was a special order.
Any color/combination could be a special order.
1954 was the first Advance-Design year with a an optional two tone exterior/interior (an option code).
cuzin #1213441 04/17/2017 1:44 AM
My 54 was two tone under the paint when I accuired it .it was blue but I cannot remember weather the cab was a dark blue with lighter fenders or light blue with dark blue fenders.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
cuzin #1213446 04/17/2017 2:04 AM
Just took a look at the tag on the drivers door paint code says FC56 my truck is a Canadian built gmc .
"The Journey"
Follow in the DITY
cuzin #1213503 04/17/2017 12:46 PM
Thanks everyone for the great information. Didn't realize that two-tone in 1952 was special order and that you could order any (available) color combination. I've only seen black fenders. Awesome information. Cuzin
KEVINSKI #1213521 04/17/2017 3:25 PM
I don't think there is a tag in 1952 with a paint code. cuzin
