11 members (David Bush, msmall, Southerntruck, Tyler Watts, Hush, JW51, Hotrod Lincoln, jasrking, Joe H, Gray_Ghost, Forty9),
105
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 17 New Guy | | New Guy Joined: Apr 2017 Posts: 17 | Is there any way to tell the original color of a 1952 3100? I noticed that passenger cars have a model id tag on the cowl.. Do trucks have something similar?
Thanks, cuzin | | | | | Joined: May 2015 Posts: 11,047 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,047 | Unless the bed was removed for any repaint job, the back of the cab and front panel of the bed should still show the original color. May be faded quite a bit, but you should be able to match it with the fairly limited selection of factory colors. I don't know the actual numbers versus other colors, but most pickups were painted forest green.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1952 USA Chevrolet truck color information. As posted by Kevin: Forester Green was the regular/standard color. There was no color code tag/plate/indicator in that year. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | If you have a patch of paint somewhere, preferable a vertical surface, that is not rusted through, wash the dirt off, give it a good going over with rubbing compound. A final rubbing with polishing compound and a coat of wax and you will have no problem identifying it from the color swatches for that year. It's not like there were 10 shades of blue.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You might take a look under the hood. I've seen many GM trucks and cars with the color name and code written on the underside of the hood.
Bill Burmeister | | | | | Joined: Apr 2017 Posts: 17 New Guy | | New Guy Joined: Apr 2017 Posts: 17 | Thanks everyone. Basically, without evidence of original paint showing somewhere, there is no official plate with a paint code. So, you can re-paint the truck any of the colors available (including two-tone) and it would be considered original. Let me know if I'm wrong.
Was the two-tone any color with black fenders only? Thanks and Happy Easter, cuzin | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | No, a repaint won't be considered original. Original paint is the paint applied at the factory. It would be considered factory correct. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | In 1952, two-tone was a special order. Any color/combination could be a special order.
1954 was the first Advance-Design year with a an optional two tone exterior/interior (an option code).
| | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | My 54 was two tone under the paint when I accuired it .it was blue but I cannot remember weather the cab was a dark blue with lighter fenders or light blue with dark blue fenders. | | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | Just took a look at the tag on the drivers door paint code says FC56 my truck is a Canadian built gmc . | | | | | Joined: Apr 2017 Posts: 17 New Guy | | New Guy Joined: Apr 2017 Posts: 17 | Thanks everyone for the great information. Didn't realize that two-tone in 1952 was special order and that you could order any (available) color combination. I've only seen black fenders. Awesome information. Cuzin | | | | | Joined: Apr 2017 Posts: 17 New Guy | | New Guy Joined: Apr 2017 Posts: 17 | I don't think there is a tag in 1952 with a paint code. cuzin | | |
