| | | Forums66 Topics128,165 Posts1,056,987 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | Anyone know where to buy a 12 volt starter?? If there is already a thread on this topic, I apologize!
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | Steve, post this in the "Parts Wanted" forum in the Swap Meet section, more folks might see it there and one may have what you need.
Make 2 more posts and you can send and receive PM's.
1959 3100 Apache Fleetside
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If your '54 has a stock flywheel you can't use a 12V starter with it. | | | | | Joined: Mar 2010 Posts: 10,299 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,299 | As cletis posted, you can't use a 12 volt starter with a stock '54 flywheel. Additionally, you do not need to use a 12 volt starter when converting to a 12 volt battery. The 6 volt starter not only works powered by 12 volts, it starts the engine Right Now since it turns the engine faster. Carl
| | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | OK, I hear ya loud and clear now. Thank you very much the knowledge you all have on this sight. | | |
