7 members (jmoore, Gdads51, MickeyP, Biermann, papas52, Otto Skorzeny, Donf), 136 guests, and 2 robots.
Topics128,162
Posts1,056,949
Members48,458
#1213282 04/16/2017 2:07 AM
Anyone know where to buy a 12 volt starter?? If there is already a thread on this topic, I apologize!
Steve, post this in the "Parts Wanted" forum in the Swap Meet section, more folks might see it there and one may have what you need.
Make 2 more posts and you can send and receive PM's.
1959 3100 Apache Fleetside
If your '54 has a stock flywheel you can't use a 12V starter with it.
As cletis posted, you can't use a 12 volt starter with a stock '54 flywheel.
Additionally, you do not need to use a 12 volt starter when converting to a 12 volt battery.
The 6 volt starter not only works powered by 12 volts, it starts the engine Right Now since it turns the engine faster.
Carl
OK, I hear ya loud and clear now. Thank you very much the knowledge you all have on this sight.
