1 members (Hotrod Lincoln),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 14 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2016 Posts: 14 | Are the windshield frames the same between the civilian trucks and the military versions i.e. G506 and GMC CCKW. ? Thanks | | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | My best guess would be yes and no. A few years back, I was salvaging a door for my 39 3/4 ton JD chevy from a large military truck from the 40’s in a junk yard. It appeared that the cabs were the same and the door worked fine. My best recollection was that the windshield frame appeared to be the same size but the mounting hardware was different. Instead of crank-out, there were sliding brackets with lock down bolts on the side. | | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Hello Gents, the windshield for the 41-46 4109 is the sames as the civilian model with the same style of windshield crank, however the CCKW and G506 have adjusting arms attached to each side of the frame similar to a WillyS MB or FORD gpw. | | |
