| | | Forums66 Topics128,088 Posts1,056,114 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 44 Member | | Member Joined: Jul 2006 Posts: 44 | I have a 1935 pickup that is dark, dark blue. Just wondering if there is a paint code or description for this color. I would like to paint it the same color if possible.
Thanks, Dan | | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | Hi Dan, Have you checked with Jim Carter Antique Truck Parts or one of the other suppliers? They usually have a list or table of what paint colors were available for each year. I'd start there and see where that gets you. I think there was a dark blue color back then but not entirely sure. You can also buy the correct paint from those suppliers. Carter is my preferred supplier for everything.
Neil 1940 GMC 1/2 Ton
| | | | | Joined: Jul 2006 Posts: 44 Member | | Member Joined: Jul 2006 Posts: 44 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Jim Carter lists Boatswain Blue (a dark blue - navy blue) and a Windsor Blue (a lighter blue). http://www.oldchevytrucks.biz/catalog4/00104.htm | | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | The standard 1934-36 Chevrolet truck color is T-140 Boatswain Blue. That is the only Blue color for 1934 & 1935. In 1936 T-160 Export Blue was added; it is a lighter blue. All trucks were painted in 1934-36 with DuPont Dulux enamel paint.
34 & 35 trucks are the greatest
| | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | The original paint that I had on my '34 was the same dark blue that you're describing with black fenders. | | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | Old Gold Yoour truck had the standard color combination for 34 & 35. Your windshield frame, headlamps & supports, grille screen, cab top as well as the fenders and running boards, wire wheels were all colored black.
