2 members (carbking, TUTS 59), 108 guests, and 2 robots.
Topics128,029
Posts1,055,416
Members48,422
#1212 04/09/2002 12:55 AM
Well, out here in Idaho it is now gettig warmer and dryer so it is time to get back in the old truck stuff. I found a seems to be good 261 and will fix it up to drop in the 49 3/4 ton I will restore, my question is I have a 11" clucth and ring gear/fly wheel out of the old 235 6 volt. I would like to use it instead of the 10" 12 volt stuff that came with the 261, anyone see any problems..............more stuff to come as I'am just gettig started. Oh are all parts houses afraid to look up old parts can't find tie rod stuff at any Napa or others all want part numbers...
sader dog
#1213 04/09/2002 1:31 AM
Junior Member
Junior Member
Just make sure that the gears mesh, there are two different types. You can find info on this in the driveline section.
#1214 04/09/2002 4:51 AM
Only problem I can think of is getting the clutch assembled in the bell housing. You might not be able to get the fork on the ball stud because of the thickness of the pressure plate assembly. I was told that a good GM parts dealer can get shorter ball studs. As for parts houses, I have a local mom & pop parts store with a long row of books, and they know how to use them.
One more thing, if you don't already know. You will need to use your 6 volt starter, gears are different. but it will work great as long as you don't sit and crank on it for too long.
Fred
52 3600
69 C-10
