6 members (Gdads51, Forty9, Rusted Nut, 39Master85, BC59, 1 invisible), 94 guests, and 1 robot.
Topics128,132
Posts1,056,376
Members48,441
#1212791 04/12/2017 12:48 PM
I know that the drive shaft needs to be shortened 3 inches. I don't want to cut my original drive shaft. My truck is a 59 1/2 ton all original drive train.
I procured another drive shaft and now find that the universal joints are not the same size. The caps are different sizes as well as the width across the joint. I seem to remember 40 yrs. ago you could buy a conversion u joint that would have different size caps, but I don't remember if the width across the caps were different. Any ideas from those who have done this already? How did you do this.
Tommy
59 apache 1/2t
261 short stepside
Any driveshaft shop can hand you the crossover u-joints that you need- they do it every day... No prob!
~ Dave
Thanks Dave, The drive line shop that is shortening the shaft said gotcha covered, don't worry about it. Seems it is a common u joint that gets used.
Tommy
59 apache 1/2t
261 short stepside
You could just as well have them put a more common yoke on the shaft for you that matches the Diff. Either way works.
The drive line shop had the conversion u joint on hand. One axis is the width and diameter of a 80's model gm product and the other axis is the size of the older gm products. They said it is a common u joint that is available anywhere if I ever needed a replacement.
Tommy
59 apache 1/2t
261 short stepside
