| | | Forums66 Topics128,078 Posts1,056,031 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | I need new cab side hinges for my 46. It looks like the old ones were damaged when the truck backed up with the door open. The new door sits up too high and won't close...not even close.
In the past month, I found them...but can't remember where. Anyone know where I can find new cab hinges for my 46 1/2 ton? | | | | | Joined: Jul 2003 Posts: 31 Junior Member | | Junior Member Joined: Jul 2003 Posts: 31 | | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | You also might want to check out Bowtie Bits. He may have them. George | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Thanks George and Wayne,
I might see if can tweak the ones I have and get them straight again.
Ouch...$200...I wish I had bought the set on E-bay this morning for $90... | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | If you have access to a 41-46 GMC service manual, it has the procedures to straighten up your doors. It involves a 2x4 in the hinge and tweeking the door closed/open. If not, email me directly and I'll see if I can get you a copy. George | | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | I should have some hinges here John. | | |
