1 members (Hotrod Lincoln), 79 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#1212454 04/10/2017 4:01 AM
Will a bellhousing from a 67-72 4 speed truck bolt to earlier crossmembers?
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
H Online: Content
It should bolt up to any of the crossmembers that have angled motor mount pads- - - - -1954-up, I believe. 53 and earlier has flat mounting pads and require a different bellhousing. The V8 bellhousings from the 55-62 trucks will also bolt up to the 194/230/250/292 6 cylinders and the Mercruiser 4 cylinders as well as the V8's.
take a look at this: www.stovebolt.com/techtips/engines/bellhousings
Something to be aware of, make sure the opening of the bellhousing where the transmission front bearing retainer plate goes is the size that fits the plate.
1959 3100 Apache Fleetside
Ok, so if one were to use a later V8 bellhousing in a 54 series truck...
What clearance issues are there if doing a V8 swap? I know there are issues with the steering box and HEI distributors. What about valve cover, etc... Will the footwell/firewall need trimmed to clear the new bellhousing?
"The Fake Truck"
1955-1956 265 left exhaust manifold clears steering box, small cap HEI clears firewall, VC's clear, no trimming necessary with standard transmission.
Evan
Evan, what year truck?
"The Fake Truck"
1947-1955.1 AD trucks.
Evan
