| | | Forums66 Topics128,076 Posts1,055,925 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Will a bellhousing from a 67-72 4 speed truck bolt to earlier crossmembers? | | | | | Joined: Feb 2004 Posts: 29,778 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,778 | It should bolt up to any of the crossmembers that have angled motor mount pads- - - - -1954-up, I believe. 53 and earlier has flat mounting pads and require a different bellhousing. The V8 bellhousings from the 55-62 trucks will also bolt up to the 194/230/250/292 6 cylinders and the Mercruiser 4 cylinders as well as the V8's. Jerry
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | take a look at this: www.stovebolt.com/techtips/engines/bellhousingsSomething to be aware of, make sure the opening of the bellhousing where the transmission front bearing retainer plate goes is the size that fits the plate.
1959 3100 Apache Fleetside
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Ok, so if one were to use a later V8 bellhousing in a 54 series truck...
What clearance issues are there if doing a V8 swap? I know there are issues with the steering box and HEI distributors. What about valve cover, etc... Will the footwell/firewall need trimmed to clear the new bellhousing? | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | 1955-1956 265 left exhaust manifold clears steering box, small cap HEI clears firewall, VC's clear, no trimming necessary with standard transmission.
Evan
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 |
Evan
