| | | Forums66 Topics128,269 Posts1,058,399 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 11 New Guy | | New Guy Joined: May 2009 Posts: 11 | Hi, I just installed an original 6 volt wiper motor (#5047765) in my 54. I have the foot pedal washer also and with the old vacuum motor the washer would turn on the wipers too but there doesn't seem to be a way to connect the cable from the washer to this electric motor. Has anybody seen a 54 with both? I'm not using the cable from the washer now and it's not a huge deal, Thanks for any help, Tom | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The 1954 Chevrolet truck electric wiper has a place on the top for clamping the washer's foot-pedal cable.
I'll see if I can find a link to a photo. Greg Hill might have a link to a few photos. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: May 2009 Posts: 11 New Guy | | New Guy Joined: May 2009 Posts: 11 | Thanks Tim, I have seen a 57 motor and it has different plastic sliders than the 54 motor. I had also seen the pics of yours in a post with Lonnie Cook and he has the same motor as mine. Maybe a 57 cable could somehow attach to it with some small parts but not sure | | | | | Joined: Aug 2001 Posts: 1,307 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,307 | If you solve the mystery, let me know. A friend in OR and I have never found the answer. I did find a bulletin that described trimming the cable to resolve a problem when used with the electric wiper motor but I can not find the definitive answer. I suspect that there was either a different switch plate or a modified mount to give it the ability to hook up to both cables yet let each one work independently of each other. just e-mailed some info to the address in your public profile. Hope it helps.
| | | | | Joined: May 2009 Posts: 11 New Guy | | New Guy Joined: May 2009 Posts: 11 | Thanks Greg, That seems to make sense about the switch plate. Maybe we'll come up with the answer eventually. Haven't got anything yet in my e-mail but sometimes it's slow. Thanks again, Tom | | | | | Joined: Aug 2001 Posts: 1,307 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,307 | The red book shows washer installation but no detail on electric wiper motor. This really is a "hunt for a unicorn" trying to find any info of that particular combination. | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | I've never seen an electric wiper setup in a 54 truck, but would I be correect it uses a cabled switch that connects to a slider? If so, I would think there has to be a cable running from somewhere on the foot pump up to the motor that would actuate the slider. I was looking at my accessory manual for 59's and all it shows is the electric foot pump and I know these are different kits. Defdinitely a head scratcher... I looked online for a chevy truck club, and found one: chevyclub.com. Somebody there may be able to answer this question.
1959 3100 Apache Fleetside
