9 members (3B, BarryP, Ribside, DadsFirstPickup, Ol' Red, Donf, Biermann, Jon G, UtahYork),
142
Mod | | | Forums66 Topics128,134 Posts1,056,738 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2003 Posts: 101 | Bought a complete door kit, for my 51 GMC, that has a rubber deal that the wing window closes against. The sent a bunch of little rivets and a rivet punch. I can't see how you would be able to seat the rivets since the vent frame is in the way of your hammer. I tried to spread one rivet on my anvil and it took some pretty heavy whacks.
Any tricks, tips, or ideas?
Sidehill | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I couldn't get the rivet/rivet punch to work either. I found pop rivets work. That is what holds my rubber strap on my wing window.
No problem. I am not a profectionist or originalist.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the rivet punch supplied goes against one side and is smucked w/ yer hammer, the other side needs to be held against an appropriate size/shape "anvil" - does help to have some experience setting grommets Bill | | | | | Joined: Jul 2003 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2003 Posts: 101 | Thanks guys
I think I'll go the pop rivet route and hopefully avoid the originalist rivet police.
Sidehill | | |
