4 members (ShopRag, joe apple, 1955 1 Series, dt235sd), 375 guests, and 5 robots.
Topics128,154
Posts1,057,015
Members48,460
Anyone out there changed a 3/4 ton to open driveline? I have a 1940 Chevy 3/4 ton with 1957 235. Trans appears to be original 3 speed. The torque tube has 2 ball joints. The chassis is 10 inches longer than 1/2 ton. Can I run a one piece open driveline?
Yes you can but you would have to change the transmission and rear axle to accept a open drive shaft.
Heavy modifications.
I'm thinking about auto trans. and a rearend from a later open drive truck. I want to keep my 6 lug wheels.
Crowejam- When I changed my '52 3/4 ton GMC from half and half, to open driveline (taken from a '59 1 ton Chevy), I had my SM420 rebuilt as well. No comment on the auto trans, but not too long after the driveline change, I ditched my 4.57 for a 4.10... It's nice! Unless I'm mistaken, 6 lug wheels aren't normal for a 3/4 ton.
Jorb- Agreed! I thought about a 1 piece driveline, but when I discovered how much it would cost, I kept my 2 piece setup.
I have to change transmissions anyway if I go with open driveline because I'm told there is no way to convert my 3 speed. I'm pretty sure my 6 lug 15 inch wheels are original. I think the 1/2 ton has 5 lug.
6-Lug = 1/2 ton
8-Lug = 3/4 & 1 ton
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Crusing in the Passing Lane
Some GMC 1 tons came with 6 on 7.25 artillery wheels.
Ed
1940 3/4 ton is 6 lug. There is also a 3/4 ton Special which was the heavy duty 3/4. Maybe it had 8 lugs but the standard 3/4 has 6.
DLBrooks
DLBrooks
If 6 lug, you might use a 12 bolt from a 67-70 or 8 lug use a srw 14 bolt. I used a 70's srw in the 46 3/4 ton - 3.73 gear behind the 54 235 with a 4 speed crash box from a 41 1 1/2 ton dump. I believe the 46 3/4 had a 4 speed enclosed on first half and open on second to rear diff. pre 47 3/4 rear drums are hard to come by. The 41 dump 4 speed was open on both halves. Had to move perches and shock mounts on both.
My 46 3/4 ton had 8 lug wheels oem.
I have a 12 bolt ready to go - already set up for a 46 3/4 ton, but is a long drive from Oregon to Cincy. 8-)
1959 GMC 100 Fleet
Follow in the DITY
Thanks for the info. I'm still in the "thinkin bout it stage" but every time I get on here I learn more.
Jim
