1 members (Otto Skorzeny),
85
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,941 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 37 | I have seen restored Chevy trucks with the 216 engine with bellhousings painted gray like the engine, black and sometimes bare. Does anyone know which was factory correct? Thanks
My rule of life: You can have anything you want; you just can't have everything you want.
| | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | supposed to be bare metal- 99% sure about that. However, I used a "cast iron gray" paint so I wouldn't have to worry about rust- looks close to the original bare metal. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I suppose it would depend on what plant built the engine. I know that on most Chevy muscle cars and Corvettes the bellhousing has overspray on it from when the engine was painted, it was attached to the block but not painted other than the overspray. I like oldcar's idea, maybe add a little gray overspruy at the front after the cast iron paint to add some authenticity.
Bill Burmeister | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | I would have to say the bellhousing was painted the same as the engine block. It is my understanding that the engines were mostly assembled and then spray painted. So I assume the flywheel and clutch were installed, and if the bellhousing were not on, the paint might interfere with the clutch mechanism. At least that is my theory, and I have heard from others that the bell housing was painted. And before I rebuilt my engine, there were traces of gray paint on the bell housing and the shield under it. And I do not think the engine had been overhauled and repainted, but I could be wrong. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The '62 261 I have came with the bellhousing painted same green as the engine. It had never been out of the truck I pulled it from. The other bellhousings I have found are black or just caked with dirt.
