0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#1212302 04/09/2017 3:57 AM
Not me, the truck. grin So we got the fuel line bled and connected to the rebuilt carb on the rebuilt engine (already broke in, found carb problems). Runs with a small stumble. Gets much worse when under load (tried TI do short drive). Had my son watch fuel filters and found bubbling into filter matches stumble. Th rubberline from valve on bottom of tank is new and rest of line steel to the first filter. A filter on either side of pump. Could there really be damage in a steel line that sucks air, but doesn't weep when truck is off?
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
52vff #1212307 04/09/2017 5:17 AM
maybe the pump is having trouble pulling fuel through the first filter.
52vff #1212356 04/09/2017 3:40 PM
Carb ination?
Sorry, couldn't help myself
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
52vff #1212363 04/09/2017 5:52 PM
Moderator
Moderator
2 Offline
I think BC has hit the issue.
Suction from the pump to the pre filter is drawing air in.
When the engine is not running, there is no pre pump line pressure or vacuum.
Other than a little static head pressure from the tank.
Fuels pumps are just a small rubber diaphragm pump.
My suggestion is to get rid of the pre filter or move it to the discharge side of the pump.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
52vff #1212415 04/10/2017 12:41 AM
Think we found it. I think I worded poorly. The "rest of the line is steel" is not new. Found it to be just barely damp over a 3" portion. Not wet, not leaking. We missed it in the poor light I guess.
BC2, 2-ton, I will keep the filter issue in mind once replacement steel line is in place. I put that filter in to catch any crap from the original fuel tank before it got to pump and filled it with crud.
MikeE that is definitively the problem! The carb doesn't like carb ination!
"Old Smokey'"
