0 members (), 128 guests, and 2 robots.
Topics128,167
Posts1,057,021
Members48,458
How do you know if the pitman arm is on far enough on a 1950 1/2 ton ? there are still splines showing on the pitman arm. the shaft splines are about 1/4 from the top of the pitman arm
THanks
1953 3100
It's tapered. There will be some splines showing. About 200 pounds torque.
THanks!
1953 3100
