4 members (kbenz, cmayna, Cletus1950, 1955 1 Series), 94 guests, and 1 robot.
Topics128,156
Posts1,056,871
Members48,456
C Online: Content
How do you know if the pitman arm is on far enough on a 1950 1/2 ton ? there are still splines showing on the pitman arm. the shaft splines are about 1/4 from the top of the pitman arm
THanks
1953 3100
It's tapered. There will be some splines showing. About 200 pounds torque.
C Online: Content
THanks!
1953 3100
