2 members (Deegs53, Bucker), 144 guests, and 4 robots.
Topics128,183
Posts1,057,194
Members48,465
Got the Viking 60 running and stopping but no speedometer action Ant suggestions on how to test if it's a speedo prob or cable problem? Does anyone know the speedo cable parts number it's a 283 with Muncie sm420 tranny. Thanks pete
The 1958 TRI-FECTA
Stepside, Fleetside and Cameo
More Fleetside pix
More Cameo pix
More Apache Stepside pix
Unscrew the cable from the transmission, chuck the cable into your battery drill, rev it up and have a helper tell you if the speedometer is working.
If that works, reconnect the cable and jack the truck up off the ground, set it on jack stands, disconnect the cable from the speedometer under the dash, start the truck, put it in gear and see if the cable is spinning. If it's not spinning then the problem is down at the transmission.
If the first step didn't work, pull the cable out of the outer jacket and see if it's broken or has a bad end. Universal cables are available and can be cut to length and slid back into your original jacket.
You could also have a bad speedometer head... ohwell
Hope this helps,
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Wouldn't the speedo cable be the same for all the TF trucks?
1959 3100 Apache Fleetside
Thank youMike. I'll give those steps a whirl
The 1958 TRI-FECTA
More Fleetside pix
More Cameo pix
