3 members (cmayna, TUTS 59, 1 invisible), 146 guests, and 3 robots.
Topics128,070
Posts1,055,896
Members48,428
#1211747 04/05/2017 4:18 PM
I have a 55 second series. When I purchased the truck the prior owner moved the fuel tank to the back of the truck under the bed and changed the tank to a 34 gallon size. The fuel gauge works, however, will only register half full when it is completely full. I guess there is no easy fix for this and most likely will have to remove the bed so that I can change or reconfigure the fuel sensor. Does someone have a better idea or an easier fix? Thanks, Pete
Pete O #1211764 04/05/2017 6:19 PM
I would be more concerned if the gauge read 1/2 full when the tank was empty. Run it fairly dry and drop the tank. No easy fix I know of.
Pete O #1211809 04/06/2017 12:16 AM
Pete O #1211906 04/06/2017 5:21 PM
I have the opposite problem (sort of). I did double check the ohm reading. My new sending unit is rated at 30 ohms and the new 12v gauge I bought is also rated at 30 ohms. When I fill up the needle buries all the way to the right past the full mark. It goes at least 1/4 to half a tank distance past the full mark. The strange thing is that once my fuel level gets down to about 3/4 of a tank the needle is reading close to the 3/4 mark. When I am sitting on 1/4 tank it is darn close to right. I test this theory by checking how many gallons it takes to fill the tank. Based on the capacity listed in the owners manual the amount of fuel needed to fill the tank is very close to what you would expect sitting at a 1/4 tank on the gauge. This is a gremlin I just live with because on the low end I know it is close to accurate.
Dave from Northern Kentucky
My 54 3100
Pete O #1211936 04/06/2017 9:21 PM
I was having a similar problem with the stock set up in my '57 3600. When the tank was full, it would only read 3/4. More of an annoyance than anything, but it was an easy fix.
With the tank completely full, I pulled the sending unit and carefully bent the float arm down until the gauge read just a touch over the white full dot. I did the bending in small increments, reinstalling and testing each time until I got it right. I did this with a disconnected battery and only reconnected it when I was checking it.
My gauge is now accurate. I just need to remember that empty really means empty!
If you can get to your sending unit without removing the bed, perhaps you can do something similar.
Matt
Maybellene #1212079 04/07/2017 9:03 PM
Great tip! I will have to remember this one...
1950 3100 5 Window
http://imgur.com/a/DAVYB
Moderated by  ndkid275, Phak1
