9 members (JoergK., klhansen, Hotrod Lincoln, Stovebolt48, 1955 1 Series, Bill Hanlon, fonz8261, latroca52, 1 invisible),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,195 Posts1,057,373 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 63 Member | | Member Joined: Feb 2004 Posts: 63 | Hello Everyone, My question has to do with repairing a base/clear paint job.I have to sell a car that is in exelent shape other than the paint has a few door dings and light scratches.I have herd that you can make the repair(fill/sand/primer/ect.)then just shoot color over the repair only then clear the whole panel.Is this correct?Also to make the rest of the undamaged areas look fresh I have heard from the same person all I need do is sand with 500 grit and re clearcoat is this also correct? As always thanks for the input. Aaron | | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | Yes you can base over your repaired area then clear the whole panel ,just make sure you leave enough room to blend out your color.You need a min. of 18 inches is recomended but depending on the color the area,body lines etc. you can bend the rules a little.As far as making the undamaged panel look fresh 500 grit is a little coarse in my opinion we use a min of 800.The only thing I don't like about this method is that it takes the factory orange peel away and the new coat of clear goes on much smoother than the rest of the car making it look repared.Try some stuff called blend prep it is fast and does not cut too deep.If you just want to freshin it up try polishing it good luck and I hope this helps | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | BENT knows what he is doing, but I would like to add that doing a repair like this in the body shop, we use the yellowish, (in place of dark red-more coarse), scotchbrite pad on the rest of the panel (in place of your 500grit). (opinion or ease?) -shrug- Good Luck. Colin | | |
