8 members (klhansen, Shade Baby, Shaffer's1950, JW51, Cosmo, Oswald, 2 invisible),
57
Mod | | | Forums66 Topics128,075 Posts1,055,919 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 14 New Guy | | New Guy Joined: Sep 2013 Posts: 14 | Other than calling a locksmith, anyone have any ideas how to unlock the lock on a rear clamshell on a 49 Suburban. Don't have a key. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Cletis is our resident lock guru and a suburban owner. Might send him a PM.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You could pull a door lock and get the number off it and take it to a locksmith. Unless of course you have a door key and it doesn't work in back, Other than that, a set of try-out keys is about your only hope. Unless you want to drill out the cylinder. I'd be sure a new one could be had before I went that route. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Don't drill any locks out just yet. You can remove the lock assembly/ t-handle all in one piece and I could most likely make you a few keys for it. ,,,,if you cant find someone locally. I have Door , ignition , locks, already keyed w/new keys set to go. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Woops, sorry, that post ended up being a "for sale" post. Please delete and ill P.M. the orig. poster with my info. | | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | What are try out keys, Charlie?
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Try-out keys are a set of 64 keys that will work on any GM lock from 1935 to 1966. I don't know how they do it. There were 1800 different key codes but I've never come across a lock one of these 64 won't open. | | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | Why not call the locksmith? When I got my '65, I only had an ignition key. No key for the door. Called one of our local mobile locksmiths and he came out to the farm and made me two new keys to fit within 30 minutes. I forget how much it was but I remember that it was remarkably reasonable. And I didn't have to disassemble anything
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | I used to amaze my students by opening Master padlocks with pick tools I made from pieces of hacksaw blades. With a little patience and persistence, there are very few locks that can't be picked if they have even a little rotating slack. Jerry
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | How do you remove the lock/handle assembly without the clamshell open? This comes up every so often so instructions would be helpful. 🚧
