7 members (cmayna, FAST55, Phak1, Cletus1950, Peggy M, Flatblu4748, Charles in CA), 74 guests, and 3 robots.
Topics128,128
Posts1,056,687
Members48,452
#1211473 04/03/2017 9:30 PM
Other than calling a locksmith, anyone have any ideas how to unlock the lock on a rear clamshell on a 49 Suburban. Don't have a key.
heavchev #1211475 04/03/2017 9:49 PM
Cletis is our resident lock guru and a suburban owner. Might send him a PM.
heavchev #1211516 04/04/2017 2:13 AM
You could pull a door lock and get the number off it and take it to a locksmith. Unless of course you have a door key and it doesn't work in back, Other than that, a set of try-out keys is about your only hope. Unless you want to drill out the cylinder. I'd be sure a new one could be had before I went that route.
heavchev #1211527 04/04/2017 2:50 AM
Don't drill any locks out just yet.
You can remove the lock assembly/ t-handle all in one piece and I could most likely make you a few keys for it.
,,,,if you cant find someone locally.
I have Door , ignition , locks, already keyed w/new keys set to go.
heavchev #1211529 04/04/2017 2:54 AM
Woops, sorry, that post ended up being a "for sale" post.
Please delete and ill P.M. the orig. poster with my info.
heavchev #1211538 04/04/2017 3:40 AM
What are try out keys, Charlie?
Allen
1974 Stingray Corvette
heavchev #1211572 04/04/2017 2:26 PM
Try-out keys are a set of 64 keys that will work on any GM lock from 1935 to 1966. I don't know how they do it. There were 1800 different key codes but I've never come across a lock one of these 64 won't open.
heavchev #1211602 04/04/2017 6:20 PM
24601
Why not call the locksmith? When I got my '65, I only had an ignition key. No key for the door. Called one of our local mobile locksmiths and he came out to the farm and made me two new keys to fit within 30 minutes. I forget how much it was but I remember that it was remarkably reasonable. And I didn't have to disassemble anything smile
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
heavchev #1211672 04/05/2017 3:23 AM
I used to amaze my students by opening Master padlocks with pick tools I made from pieces of hacksaw blades. With a little patience and persistence, there are very few locks that can't be picked if they have even a little rotating slack.
heavchev #1211762 04/05/2017 6:15 PM
How do you remove the lock/handle assembly without the clamshell open? This comes up every so often so instructions would be helpful.
