9 members (Lightholder's Dad, Otto Skorzeny, MickeyP, Gdads51, FAST55, dt235sd, Pre '68 Dave, Peggy M, 1 invisible),
96
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,652 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 7 Junior Member | | Junior Member Joined: Apr 2006 Posts: 7 | I've read in past posts about Stovebolters using J-B Weld to fill holes rather than the traditional "Bondo". Is this a good way to go aside from cutting out the rot and/ or welding in new panels? I imagine it would more be dificult to work with. I know it's still filling holes. Is J-B Weld porous like bondo is? Thanks for any thoughts. | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | NOT very cost effective. Isn't JB Weld only available in small tubes? You'd have to buy like 2 cases of the stuff to skim coat a fender. Stick with the stuff that's made for the job. What would be your reason for wanting to go with JB Weld instead of body filler?
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That stuff is hard to sand too. Bondo isn't meant to fill holes either. You'll be better off cutting out the rotted metal and welding new, it'll be stronger and last longer. Save the filler for final finishing.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | if its a big hole get a fiberglass kit from napa or hardware store tape the back side of hole glass it when dry bondo and smooth will last a few years get your metal clean first | | | | | Joined: Apr 2006 Posts: 7 Junior Member | | Junior Member Joined: Apr 2006 Posts: 7 | Pakrat 48, Longbox 55, 32 Fire 2, Thanks for responding.
Pakrat 48, When I was wire burshing the bottom corners of the driver's door on my '63, I found it was really bad with rust. Nice half dollar hole on lft side. Almost as bad on the rt. Rot goes all the way through to the inside. I didn't want to just pack it full of Bondo. Was looking for a better way. Killerdude | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Like Longbox said, it sands hard. It's made to be drilled, tapped, filed and such. Besides, it would be near impossible to feather the edges, you'd always be able to see the repair. Cut out the old and patch in new metal, that's always your best bet.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Jan 2002 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2002 Posts: 59 | I used JB weld to fix some pin holes in a stepside bed where the fender flange bolts on. just cleaned the metal with a wire wheel real good first. It sanded ok. rust never came back through and I drove that truck for years.... | | | | | Joined: Jul 2000 Posts: 580 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 580 | I've used it to fill some pinholes in my cowl area during my windshield job. I welded the bigger holes. I used it because it's waterproof and it doesn't shrink. Normal filler was used on top of that. It's been a couple of years now and no sign of rust. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | you can buy a lower door repair panel. I repaired my doors using welded patches(from an old hood), then filled the corners w/brushable seam sealer to completely fill the lower corner that traps water, now they are smooth inside on the corners, water will drain out now. I did this to my 79 Ford about 7 yrs ago, still good, it is stored outside(the 2 Chevies are inside the shop),,brian | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I used it on a rusty, leaky hole on the door of the dishwasher in my old house when I was too much of a bachelor to get a new dishwasher. It looked horrible because I didn't finish it smooth, but it held up to hot water. It was still there 3 years later after I got a new dishwasher.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Apr 2006 Posts: 7 Junior Member | | Junior Member Joined: Apr 2006 Posts: 7 | Thank you, Gentlemen. 4onthefloor, I did hear of a fella who had an old iron duke chevy 120cid and used JB Weld to fill a crack in the block. The man said he had water squirting all over the place. This motor was in a boat. One application and it never leaked again. He did sell the boat directly afterwards. Killerdude | | |
