Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (68ironhead, Ridgeback, 78buckshot, Oswald), 101 guests, and 6 robots.
Topics128,274
Posts1,058,436
Members48,490
#1211447 04/03/2017 6:00 PM
Hello,
On 47-50 trucks there is a vent door on the side just ahead of the door. If the an assist spring that helps to keep the door closed? If there is, does anyone have a picture of it? Otherwise how does it keep a good seal? Mine seems to a bit of free movement within the handle lock.
On the '48 standard cab there was an over center spring that held it closed and I think fully open. Handle with a plastic knob same as the cowl vent.
On the '51 COE the lever is smaller and slides in a slot that has a notch for the lever to lock into when it's closed. I believe friction holds it open to any place you set it. No knob, just a metal lever.
Have you replaced the rubber gasket?
Original gasket is a dense foam type material. A rubber gasket is too stiff and will not seal properly. Gasket glues in with 3m weather strip adhesive. Steele products has the best weather striping and body gaskets.
Tim
1970 VW Beetle
