Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (SWEET, Wickedbass, Hanks custodian, HandyAndy, Ponchogl), 40 guests, and 2 robots.
Topics128,009
Posts1,055,297
Members48,419
#121144 07/08/2006 8:30 PM
Any tips on interior paint? I would like to preferrebly use a rattle can and it still look decent. Do I need to sand and all that if I'm going to be paint over the same color?
GO RANGERS grin
Photos Updated so check them out!
#121145 07/08/2006 8:39 PM
Rattle cans should be ok, just watch your spray pattern so you don't get "zebra striping" in the finish. You'll want to at least scuff the existing finish to give the new paint something to adhere to. You won't have to use anything too coarse, 320-600 grit should do it. Make sure to wipe it down before you paint to keep the dust and other nasties from messing uo your finish.
Bill Burmeister
#121146 07/08/2006 8:49 PM
Thanks Longbox!
GO RANGERS grin
#121147 07/09/2006 11:42 PM
One possibility would be to take a sample of the color you want to a paint store and have them match the color and put it in spray cans for you.
#121148 07/21/2006 4:44 AM
Use a scuff pad and then remove all dirt with a tack cloth and repaint.
