1 members (UtahYork), 215 guests, and 1 robot.
Topics128,101
Posts1,056,181
Members48,436
#1211332 04/02/2017 8:12 PM
Hi everyone. I found a replacement 216 for my truck. The guy I bought it from said it ran well before he pulled it (replaced with a 350). The engine looks good, I can still see the "Thriftmaster" paint on the valve cover and it turns over by hand fine. However, I took off the valve cover to find a surprise, gross rockers! What should I do?
http://imgur.com/a/nUZlB
Bryce S. #1211335 04/02/2017 8:19 PM
Pull the head and do a full teardown and cleanup. Chances are the rockers can be reused, but it's going to take more cleaning than can be done with the engine assembled. The valve springs will definitely have to be trashed, not sure about the spring retainers.
Bryce S. #1211339 04/02/2017 8:35 PM
Sir Searchalot
Sir Searchalot
Wait two weeks and then toss it.
Bryce S. #1211341 04/02/2017 8:38 PM
The "ran well before he pulled it" was either an outright lie, or it ran well and then he let it sit outside for a decade.
1951 3100
Bryce S. #1211342 04/02/2017 8:46 PM
I got a 1946 216 a few weeks ago that has holes rusted in the oil pan and flywheel cover from being buried in mud, and the rockers are much cleaner than that.
Bryce S. #1211349 04/02/2017 10:24 PM
Can you post pics of the rocker cover with the original letters?
Bryce S. #1211355 04/02/2017 11:00 PM
Sir Searchalot
Sir Searchalot
Valve Cover Condensation. Happens a lot. But it takes years of sitting. I don't have the patients, or should I say time left, to screw with that. I would buy another that WAS running now and check valve train and the oil while it was running. Too many motors out there to spend months on that. IMO.
Possibly not as bad as it looks. Possibly.
I'm sure the seller did not know it was that bad. If he is a good guy, he will give some or all money back. Unless you got it for cheap money.
Bryce S. #1211368 04/03/2017 1:12 AM
I do have the head from the original 216, which is pretty clean, are the years interchangeable? I don't know if I should mess with putting the other head on, or just ask for my money back. He was a nice guy, I don't think he knew it was like this.
The letters aren't super visible, but they are still there.
http://imgur.com/8yrHNuY
Bryce S. #1211371 04/03/2017 1:28 AM
1941-53 are interchangeable, although 1941-48 use 10mm spark plugs.
My Blog
Bryce S. #1211372 04/03/2017 1:28 AM
The "M" on the valve cover indicates that this particular original valve cover was not painted with a stencil similar to what is depicted in the design of the stickers available from the vendors.
...not to hijack your thread...
Bryce S. #1211374 04/03/2017 1:54 AM
Sir Searchalot
Sir Searchalot
Bryce: Money back. When you drop the pan you may see the same gunky rust. Buy a runner you can examine, put on new pumps, ignition stuff, clean it and go to town.
Dave: Why did 41-48 have metric threads?
Bryce S. #1211380 04/03/2017 2:57 AM
Actually before 1941 and after 1948 they are also metric, just that they are 14mm.
No ides why Chev went 10mm from 1941-48.
My Blog
Bryce S. #1211385 04/03/2017 3:36 AM
Can a 10MM head be drilled and tapped for 14MM plugs? I've got a couple of those heads.
Bryce S. #1211391 04/03/2017 4:23 AM
Sir Searchalot
Sir Searchalot
It seems Herr Robert Bosch and Monsieur Albert Champion sort of grandfathered metric into spark plugs. Champion lost his company and started A.C. (Albert Champion) Spark plug Co. Model T, A and other engines used pipe threads and SAE threads but were phased out and the Metric won.
Bryce S. #1211396 04/03/2017 4:48 AM
Ferd used 18MM tapered seat plugs for a lot of years, starting about 1955, I believe.
Bryce S. #1211448 04/03/2017 6:04 PM
He's a nice guy, he's sending me a check and letting me keep the engine.
Bryce S. #1211453 04/03/2017 6:34 PM
The title of this thread makes me chuckle. Been trying to think of Keith Richards wisecrack, but I'm not all that clever. Perhaps 52Carl can think of something.
1951 3100
Bryce S. #1211464 04/03/2017 8:03 PM
Crusing in the Passing Lane
That is real decent of the gentleman, we could use more like him.
Ed
