| | | Forums66 Topics128,274 Posts1,058,435 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | Any tips on interior paint? I would like to preferrebly use a rattle can and it still look decent. Do I need to sand and all that if I'm going to be paint over the same color? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Rattle cans should be ok, just watch your spray pattern so you don't get "zebra striping" in the finish. You'll want to at least scuff the existing finish to give the new paint something to adhere to. You won't have to use anything too coarse, 320-600 grit should do it. Make sure to wipe it down before you paint to keep the dust and other nasties from messing uo your finish.
Bill Burmeister | | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | One possibility would be to take a sample of the color you want to a paint store and have them match the color and put it in spray cans for you.
| | | | | Joined: Jul 2006 Posts: 47 New Guy | | New Guy Joined: Jul 2006 Posts: 47 | Use a scuff pad and then remove all dirt with a tack cloth and repaint. | | |
