| | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2017 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2017 Posts: 43 | Anyone out there changed a 3/4 ton to open driveline? I have a 1940 Chevy 3/4 ton with 1957 235. Trans appears to be original 3 speed. The torque tube has 2 ball joints. The chassis is 10 inches longer than 1/2 ton. Can I run a one piece open driveline? | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Yes you can but you would have to change the transmission and rear axle to accept a open drive shaft. Heavy modifications.
| | | | | Joined: Feb 2017 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2017 Posts: 43 | I'm thinking about auto trans. and a rearend from a later open drive truck. I want to keep my 6 lug wheels. | | | | | Joined: Jan 2017 Posts: 37 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 37 | Crowejam- When I changed my '52 3/4 ton GMC from half and half, to open driveline (taken from a '59 1 ton Chevy), I had my SM420 rebuilt as well. No comment on the auto trans, but not too long after the driveline change, I ditched my 4.57 for a 4.10... It's nice! Unless I'm mistaken, 6 lug wheels aren't normal for a 3/4 ton.
Jorb- Agreed! I thought about a 1 piece driveline, but when I discovered how much it would cost, I kept my 2 piece setup.
| | | | | Joined: Feb 2017 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2017 Posts: 43 | I have to change transmissions anyway if I go with open driveline because I'm told there is no way to convert my 3 speed. I'm pretty sure my 6 lug 15 inch wheels are original. I think the 1/2 ton has 5 lug. | | | | | Joined: Mar 2004 Posts: 6,232 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,232 | 6-Lug = 1/2 ton 8-Lug = 3/4 & 1 ton Mike B  | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Some GMC 1 tons came with 6 on 7.25 artillery wheels.
Ed
| | | | | Joined: Feb 2017 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2017 Posts: 43 | 1940 3/4 ton is 6 lug. There is also a 3/4 ton Special which was the heavy duty 3/4. Maybe it had 8 lugs but the standard 3/4 has 6. | | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | If 6 lug, you might use a 12 bolt from a 67-70 or 8 lug use a srw 14 bolt. I used a 70's srw in the 46 3/4 ton - 3.73 gear behind the 54 235 with a 4 speed crash box from a 41 1 1/2 ton dump. I believe the 46 3/4 had a 4 speed enclosed on first half and open on second to rear diff. pre 47 3/4 rear drums are hard to come by. The 41 dump 4 speed was open on both halves. Had to move perches and shock mounts on both.
My 46 3/4 ton had 8 lug wheels oem.
I have a 12 bolt ready to go - already set up for a 46 3/4 ton, but is a long drive from Oregon to Cincy. 8-)
| | | | | Joined: Feb 2017 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2017 Posts: 43 | Thanks for the info. I'm still in the "thinkin bout it stage" but every time I get on here I learn more.
Jim | | |
