0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: May 2014 Posts: 44 | Is there supposed to be a gasket between the engine block and the oil screen to pump oil line? I am talking about where the fixture attaches to the block with a single bolt. The other end of the line connects to the pump. The screen housing attaches over the single bolt with plate, two bolts and a gasket. It does not mention it in the shop manual and there was not a gasket when I disassembled the engine. What about using a little high temp silicone to form a gasket? Thanks for your help! | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I haven't had to tear my 216 down that far yet but I don't recall a gasket there on the 235 I rebuilt.
Are you rebuilding the engine or just working on the oil pump assembly? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | So I think you are asking about where a single bolt attaches the assembly to the main bearing cap. I just went through this. Mine didn't have a gasket and I didn't worry about it. After I had the whole thing together I discovered an appropriate circular gasket in my gasket set, oh well! I don't think it makes a difference. | | | | | Joined: May 2014 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: May 2014 Posts: 44 | Yes, where it attaches to the main bearing cap. I think I can see the faint outline of where a circular gasket was there. I was mostly worried about the pump sucking air. I think I will make a gasket just to be safe. Thanks for you help! | | |
